2012 Camry Hybrid Rear Defrost Not Working
Old Jan 24, 2021 | 12:25 PM
djromer's Avatar
Default 2012 Camry Hybrid Rear Defrost Not Working
Can't figure out the problem. i also cannot locate where the connection is to the rear defrost lines. any help is appreciated.
Old Jan 26, 2021 | 05:05 PM
Emman's Avatar
Usually the problem can be traced to a faulty electrical component. Old wiring or a blown fuse can cause a disconnect. Test it with the defroster test lamp or an automotive circuit tester.
Old Jan 27, 2021 | 05:21 PM
Connection might be on drivers side of window midway up.
Old Jan 28, 2021 | 04:45 AM
LaizaM's Avatar
You have to make sure the rear defroster switch and the ignition key are turned on. Disconnect both wires from either side of the defroster grid and touch one end of your tester to each wire. If the light comes on, you have power. If it doesn't, check for a bad fuse and replace it if necessary.
dan s.
May 17, 2021 11:30 AM
Bennyd1_99
Jul 23, 2020 01:02 PM
epwhitfield
Jan 20, 2015 06:59 PM
LindaLoo
Jun 5, 2012 01:49 AM
coveman
Jun 7, 2010 02:22 PM
