Air Flow Help PLEASE!!
Old Jul 21, 2023 | 02:01 PM
jray's Avatar
Default Air Flow Help PLEASE!!
Good afternoon. This is my first time being apart of this thread. I have a 2015 Toyota Camry SE. I've been having some issues with my air. The first time was the blower motor. I replaced that and the air blew stronger than ever. Over time I noticed the air was coming out weak. I later noticed that some napkins got sucked near the blower motor which restricted some of the air. However, after removing the napkins I was getting air from all of the vents except the two front middle vents. It blows on defrost and when switched to blow from the from vents, the air only blows through the two side vents and the floor vents, but not through the two front center vents. Does anyone know what may be the cause of this and what's the fix?
Old Jul 21, 2023 | 06:28 PM
Put the control on Face. Air should flow out of the center and side registers.
There is control damper after the air splits off to the side vents when going to the center vents. If this damper is closed there will be no air to the center vent.
Old Jul 22, 2023 | 11:54 PM
jray's Avatar
Where is the control damper?
Old Jul 23, 2023 | 10:00 AM
Best advise is to go over to Toyotanation.com in the Generation 7 Camry forum and do a search or ask. Or search YouTube videos for specific info on this not uncommon problem..
Depending on what happened one may need to take the dashboard off which is BIG job. Sometimes one gets lucky and the push//pull rod falls off the side that can be accessed without doings so. Since it can be a BIG job best to find a detailed post or video from others who have had the problem as unfortunately it is not uncommon. The Toyota service manual is not much help because it shows the area with the dash off and provides no repair with dash on info.
JHSluder
May 10, 2024 09:11 PM
Shrapon
Aug 12, 2019 06:26 PM
LegacyBB
Oct 12, 2010 11:11 AM
jkw1395
Oct 20, 2008 01:57 PM
