Need help with wheel size!!!
Old Feb 25, 2019 | 09:31 PM
Woozywarrior's Avatar
Default Need help with wheel size!!!
I have an 2016 camry se. I just recently purchased eibach lowering springs(about 1.5 inch drop) I am wanting to put some 19 x 8.5 wheel on there. I would like them to be tucked right on the inside fender. What would be the best offset and tire size to go without any rubbing or any other possible damage????? Thank you....
Old Feb 26, 2019 | 11:48 AM
Lowering springs have a height range they will lower a car. They are not always spot on at lowering a car say 1.5 inches.
Suggest you install the springs, inflate tires to the proper pressure then measure what clearances you have.
From here use an online calculator. The calculator will provide the tire location changes based on tire/rim size and offset.
KKNAPP
Mar 27, 2019 10:36 AM
demerson2
Feb 10, 2017 08:11 AM
Jason Gramajo
May 12, 2016 02:11 PM
wcast
Feb 6, 2014 11:04 PM
Ken85755
Feb 26, 2009 03:29 PM
