Transmission fluid change
Old Jun 2, 2023 | 05:05 PM
Jailbreaker's Avatar
Default Transmission fluid change
I have a 2018 camry with more than 155k miles on it. It has never had its transmission fluid changed, so it's still rocking the original fluid. Would it be a good idea for me to change the fluid at this point or should I just leave it as is?
I've heard that changing fluid at high mileages can lead to the transmission slipping.
Old Jun 2, 2023 | 09:26 PM
An issue is not changing the fluid WILL cause trans failure. Worn out fluid is the No 1 cause of trans failure.
If my car and keeping it I would change it
You might have issues with some shops changing it as they don't want the risk.
If changing the fluid then just change it. DON'T use chemical cleaners or a do a trans back flush or a power flush, etc.
stdrxw12
May 14, 2025 07:03 AM
sardrum
May 5, 2023 06:19 PM
Firefox613
Dec 5, 2022 10:31 PM
bobke1
Apr 20, 2019 05:01 PM
hooter
Jan 12, 2014 12:29 PM
