Sights n Sounds Post your video clips here.
96 Camry with 5S-FE engine - What is the name of this hose - best place to get
Old Feb 24, 2013 | 06:25 PM
tjodork's Avatar
Default 96 Camry with 5S-FE engine - What is the name of this hose - best place to get
can anyone tell me what this hose is called?
I have the service manual and while i see it in the picture I cant find it explained.....
also I showed the guy at O'Reilly's and he said I'd have to go to dealer to get..is that right or is there better places to get ?
Thanks
Tim
Attached Thumbnails 96 Camry with 5S-FE engine - What is the name of this hose - best place to get-ashampoo_snap_2013.02.24_18h09m02s_003_.jpg
Old Feb 25, 2013 | 11:05 AM
Where does the hose go? Is it a coolant, air, etc hose?
The engine has a couple of coolant hoses going to the IAC valve mounted on the throttle body.
Also this year of car might have a hose going to the emissions converter under the chassis.
Old Feb 25, 2013 | 10:48 PM
tjodork's Avatar
Hi ..its not coolant...i think it might be some gas (exhaust) not sure...there is a crack and a little oil has come out and onto spark plug wires.
Old Feb 26, 2013 | 08:39 PM
Might be an air injection tube. Follow the tube to determine if it goes to the emissions converter under the car. Would be called air injection tube for converter.
Or an EGR tube. The EGR valve bolts to the back of the cylinder head. Determine if tube comes off exhaust manifold and goes to something having what looks like a short wide can on top of something bolted to the back of the head. Would be called EGR pipe.
Old Feb 26, 2013 | 09:36 PM
full house's Avatar
I think it's exhaust... I think it's something like this http://www.artshot.net/westy.jpg
SteveS
May 2, 2011 12:25 PM
bmfyzf607
Jan 21, 2009 07:27 AM
Indolent
Jan 17, 2007 06:18 PM
99camry
Nov 21, 2006 10:33 PM
