1999 camry LE w/ tein s-techs
Old Mar 8, 2007 | 03:05 PM
jnthn's Avatar
Default 1999 camry LE w/ tein s-techs
hi all,
i installed a set of tein s-techs on my '99 camry and after driving for a while, the ABS light came on. manual says to "see local toyota dealer ASAP" however, ive been driving it, as it is my daily driver, and havent noticed any differences in drive/stopping. has this happened to anyone else or can anyone advise?
thanks!
Old Mar 12, 2007 | 04:30 AM
toyoboy's Avatar
Default RE: 1999 camry LE w/ tein s-techs
you may have damage the abs sensor while you your installing your suspention. its comman to over stretch the wirewhen you switched parts. you will need to get the codes, im just guessing what happened.
Old Mar 12, 2007 | 05:14 AM
OnE_To_HatE's Avatar
off topic question but how's the ride w/the S-Tech?.. comfort wise...
Old Mar 29, 2007 | 03:04 AM
krgs4's Avatar
You have three possibilities:
1. ABS sensor or sensors were damaged during the install $150 ea.
2. ABS ECU was shorted out $850.00
3. ABS sensor wiring was stretched/ torn. 2.5 hrs labor
most likely #1. Buy a Haynes manual for $16
Read Section 9-3 and 9-6, you will be able to pull codes off ypur dash lights...and this will tell you exactly what was faulted.
Plus you will be able to Reset your Trouble Light.
I had this happen to me on my Stech KYB Gr2 install.
gabe650
10
Sep 17, 2008 12:05 AM
mikeynavy1
Jan 10, 2008 09:57 PM
mikeynavy1
Nov 28, 2007 08:23 PM
mikeynavy1
May 24, 2007 01:31 PM
mikeynavy1
Aug 11, 2006 11:14 PM
