lowering... need new shocks?
Old Apr 12, 2006 | 12:32 AM
mrbojangles's Avatar
Default lowering... need new shocks?
ive got a basically stock 97 camry, with stock size rims, and want to lower it 1.8"... do i need new shocks too? thanks for the help
Old May 31, 2006 | 06:11 AM
trdcamrygracia's Avatar
Default RE: lowering... need new shocks?
its better if u replace performance shock at same time....becasue lower spring will kill ur stock shock faster........if u replace with performance shock it will last longer than the stock shock.....and u will save labor to do it once
Old Jun 27, 2006 | 06:18 AM
JoeGengsta's Avatar
NO!!! if you want the haywagon feel
Old Jul 16, 2006 | 07:55 PM
mikeynavy1's Avatar
If you have the means, do it all at once, especially if your stock struts/shocks have a lot of miles on them. You can leave the stock ones on but they will wear out faster on a lowered car. If they have a lot of miles, you'll save money, as was just mentioned, by only having the suspension disassembled/reassembled once. I just hope they come up with stuff for my '07 quickly. I'm already having to go with a tire and wheel combo that's not as wide as I want, and doesn't fill up the wheel well without "gap." I also don't want lowering springs. They looked good on my old '02 Nissan Spec V, but they felt like crap on any sort of bump. I had 18"s with 215/40 tires. I have 18's on my Camry now, but I'll probably stick with a 45 series tire to get a little more shock absorption.
TRDCAMRYGRACIA - What size wheels and tires do you have on? 19"s?
Old Aug 3, 2006 | 02:57 AM
ORIGINAL: mikeynavy1
on the picture is 18x8 with 225/40/18 and right now i have 17x7 with 215/50/18
Old Aug 3, 2006 | 09:04 PM
jasmtz531's Avatar
Replace both at once. The factory shocks are designed for a spring with a factory spring rate. Changing the springrate with a new spring is not a good idea, nor is it safe. Buy shocks.
-Jason
Old Jan 31, 2007 | 04:10 PM
tim96460's Avatar
Get some kyb gas shocks, very reasonable and work bitchen I have them on mine. Lowered mine (2000) 2"with 16" rims but having a hell of a time trying to locate some perf. sway bars[:@]
[align=left] [/align]
Old Mar 29, 2007 | 03:19 AM
krgs4's Avatar
Get New:
1. Shocks KYB GR2 s $309 at Shox.com
2. KYB Strut mounts $104 pair at Tirerack.
3. Tein Stechs about $248 from ebay Powerseller
I did this 3 weeks ago. My car feels like 2007 in fact this set up feels similar if not better than my Lexus GS400.
*new strut mounts are essential here because your current Strut Mount Bearings up front are shot. If you do take them apart and try to reuse them with just new Struts and Springs, you will hear louder CLUNKS, Thumps, Squeaks. Clanks than you already over pot holes.
It really is amazing that I go over bumps in the road...and it is complete silence like when I first had the car New.
b_roddd
Nov 29, 2014 10:55 PM
20s
11
Mar 24, 2009 09:45 PM
madquake
May 28, 2008 07:24 PM
turbo4cappuccino
Jul 11, 2005 12:28 PM
SammySalsa
Jun 1, 2005 03:50 AM
