2000 camry rear hub assy
Old Mar 24, 2012 | 11:08 PM
carl3330's Avatar
Default 2000 camry rear hub assy
Does anyone know if the non-ABS rear wheel bearing/hub assembly is common between a 2000 Camry & Solara? Or are there subtle differences?
It appears that Timken and SKF use the same p/n for both cars (based on a search at RockAuto), but National (MOOG) lists p/n 512009 (bearing assy only, no hub assy available that I can find) for the Camry vs. 512311 for the Solara. Based on the common Timken & SKF p/n's, I'm assuming the National 512311 hub assy will fit a 2000 Camry as well, but am a bit hesitant to purchase it off ebay when it claims to not be compatible. I'm wondering if there are slight differences that Timken & SKF took into account to achieve a common part, but National did not??
Thanks
Old Mar 24, 2012 | 11:59 PM
Might recheck the National part numbers. One appears for year 2000, the other for 1999.
Old Mar 25, 2012 | 01:51 PM
carl3330's Avatar
Joey,
Thanks for the response.
Are you suggesting that the hub assemblies are not interchangeable between a 1999 & 2000? Or that the 512311 should work on a 2000 model year since it's listed as compatible for a 1999? Note again that 512311 is a complete hub assy, while the other is just the bearing assy. I would have guessed that the design would not have changed between model year 1999 & 2000.
Could you send a link of where to check the National p/n's? I'm just looking at auto part store's websites, and I haven't found a different p/n for 1999 vs 2000 (they say 512009 for 1999 & 2000 camry).
demiandvm54
Feb 3, 2020 02:41 PM
mjdejan23
Feb 5, 2015 11:41 AM
eyeblazin
May 13, 2013 12:36 PM
demiandvm54
Nov 10, 2011 07:48 AM
demiandvm54
Nov 8, 2011 08:13 PM
