2000 Camry XLE with 16 inch wheel upgrade
Old Aug 11, 2014 | 10:43 PM
JOHNS's Avatar
Default 2000 Camry XLE with 16 inch wheel upgrade
I purchased the 2000 Camry XLE from a family member and the car runs great with over 180,000 miles. Recently the car had to sit and I need to replace the rotors - front and back.
My problem is all the parts stores tell me rotors are only available in 15 and 14 inch size and my Camry has the 16 inch wheel upgrade.
Can I get rotors to fit my Camry ( 16 inch ) ? So far I have had no luck finding an parts store that has the 16 inch rotor. I need rotors, pads the works and I've got to believe that somewhere there are rotors that will fit the 2000 Camry v6 XLE made in the USA.
Can anyone help me ? This is my first posting and I'm in need of some expert help.
Thank you.
JOHNS
Old Aug 12, 2014 | 05:43 PM
Toyota offered two sizes of front rotors, which may 255 and 275 mm. The V6 engine had the larger size and often rim size is referenced to diameter. However a 16 inch option does not mean a larger rotor was offered. Suggest measuring rotor diameter which expect is 275 mm.
sundarpn
Sep 21, 2024 08:50 AM
manllyy007
Feb 2, 2015 11:29 PM
vistacruiser67
Oct 27, 2013 10:51 AM
rcat8872
Jan 4, 2013 02:50 PM
dtbrown
Jul 1, 2007 02:39 AM
