Old 08-25-2015, 05:21 PM
How-Tos on this Topic
Browse all: Brake Guides
Print Wikipost
2010 Camry Brake Pedal Issue
Old 10-23-2014, 01:54 PM
wayno's Avatar
Exclamation 2010 Camry Brake Pedal Issue
Just had local shop (not dealer) flush and replace all break fluid. Gravity bleed. Now the brakes seem to work OK except the pedal is very soft and will go all the way to the floor. Scarey feeling. They will not pump-up. Bleeding does not help and no air comes out. I see comments about bleeding ABS module and/or master cylinder. Could these be the issue or something else? I'd appreciate any and all suggestions. Thanks.
Old 10-23-2014, 08:35 PM
Suggest starting by taking the car back and asking the shop to correct the problem. If the pedal goes to the floor, the shop should be concerned from a liability stand point and want to correct the problem.
Otherwise your options are to bleed the master cylinder, then ABS module. The module may require a electrical tester to activate it and move the fluid out the brake bleeding fittings.
Old 10-24-2014, 09:49 AM
wayno's Avatar
Turned out to be air in the module.
Thanks, Joey
Old 10-24-2014, 10:23 PM
Great, thank for posting back.
dividingbyzero
05-08-2015 09:10 AM
CamryLastFoureverNever
03-16-2015 07:57 PM
Rajeev
10-29-2009 10:25 AM
turtle02909
05-27-2009 08:16 PM
Cam95
09-14-2008 05:07 PM
Quick Reply: 2010 Camry Brake Pedal Issue
