ABS chatter, low pedal
Old Jan 1, 2008 | 07:54 PM
Quantumfog's Avatar
Default ABS chatter, low pedal
This one has stumped three garages, the last being one of the local Toyota dealerships. I've seen this question posed before here, but the response doesn't solve the problem.
The symptoms are a low pedal; the abs kicks in during a stop when traveling at any speed, even 5-10mph. ABS light does not come on to indicate a problem.
The first garage couldn't figure the solution; the second garage replaced the master cylinder; then the toyo dealership replaced the pads, machined the rotors and bled the lines. The dealership has had the car for three days without coming up with an answer.
I've seen this problem posted on several forums, all give the same pat answers about the cylinder, pads, lines and rotors. There is no follow up past this point giving a solution that works.
Anybody here smarter than the mechanics I've been dealing with?
Old Jan 4, 2008 | 11:34 AM
Quantumfog's Avatar
Default RE: ABS chatter, low pedal
"...Anybody here smarter than the mechanics I've been dealing with? "
Judging from the lack of response, I guess not.
In case anyone else runs across the same problem, the Toyota dealership called back to say the problem is a faulty ABS actuator and priced the fix at $400. After some arm twisting, they agreed to fix it at no additional cost.
Old Jan 6, 2008 | 11:07 PM
toyoboy's Avatar
of course the mechanics are smarter, they have the upper hand..they were able to test the brake system..
CamryLastFoureverNever
Mar 16, 2015 07:57 PM
apesakal
Aug 3, 2012 09:21 AM
lou7200
Sep 1, 2011 08:59 AM
granadaCoder
Jul 29, 2008 12:43 PM
miguelrzr
Nov 28, 2007 09:45 AM
