Compatibility of 7Jx15 H2 wheel rims on 2015 Camry LE
Thanks a lot. I had the same doubt. Will I be able to find a 7Jx15 rim for Camry? I want to fit a 205/65 R15 tire to it. The tire will be 1" smaller than the one currently on the car. Will it cause any problem while driving other than the error in speed and distance measurement?
This is a smaller non standard size for Camry please check https://www.wheel-size.com/size/toyota/camry/2015/ for recommended sizes. Note the ET is important as well so make sure any new wheel is around ET45. Smaller wheels lower your car so you may notice less body roll going around corners, and, will give you better acceleration but you will use more petrol.
Camryms38801
Jan 23, 2012 06:55 PM
ALERT
May 1, 2008 10:33 AM
