recommended tire specs for an 18"x 8 alloys
Old Jul 8, 2014 | 03:07 AM
raggedyman's Avatar
Default recommended tire specs for an 18"x 8 alloys
Hi there, I have an '05 camry 2.4 currently rolling on an oem 17x7 wrapped with 215/55 series tires.
Now I got an 18x8 inch alloys which I got on a very fair price. Which you think maybe the more appropriate tire specs for this kind of size (18x8 rims)?
will it be a 225/45 series? or a 245/45 series?
Any feedbacks from an 18x8 users there? Thanks in advance.
Oh. by the way my ride is not that lowered, still on a stock height and stance.
Old Jul 8, 2014 | 10:57 AM
What is the rim offset? Stock may be 40 mm.
For this rim width can use either tire, but suggest 225/45.
Check offset first for possible strut clearance issues.
Old Jul 8, 2014 | 11:44 PM
raggedyman's Avatar
the new wheel specs is 18x8, 5holes x114.3pcd, offset:ET45, center bore 60.1.
Old Jul 9, 2014 | 11:50 AM
Either tire should fit a stock chassis. Then it becomes a matter of opinion.
The new rims are 8 inch. To get the same tire "look" as current rim/tire combination requires the wider tire. The larger tires will also extend out 1/2 inch further filling the gap between tire and fender which some owners like.
Others like the 225 tires as this was the stock tire size.
The tire/rim comparer below shows how the tire/rim will look and provide chassis clearance.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
For more opinions try Toyotanation, Camry section.
peterliu2000
Aug 11, 2010 11:15 PM
J3FF
Apr 14, 2009 07:27 PM
Mr. Toyota
Dec 9, 2008 10:19 PM
09toyotaguy
Oct 5, 2008 12:56 AM
cloudnine
Nov 21, 2007 06:33 PM
