Old Aug 26, 2015, 11:16 AM
How-Tos on this Topic
Browse all: Brake Guides
Print Wikipost
soft brakes on '03 Camry SE
Old May 18, 2019 | 06:25 PM
  #11
DiViDe's Avatar
Originally Posted by wshhh
Just want to add my $.02. I have the soft pedal issue on our 2003 Camry, and have replaced: the front rotors, pads, calipers and master cylinder and bled a quart of fluid through the system, and the pedal is still soft, though the car stops like crazy (in a good sense). I will adjust the rear drums this morning, and report back. Otherwise, you may want to hold off on some of these repairs and save your time and $, as they did not improve the pedal in my case.
PS I think the booster may be a bogus issue, as there appears to be a solid connection from the pedal to the master cylinder and the booster just adds, well, boost, but doesn't effect how deep the pedal plunges. Please correct me if I have this wrong.
OK, rears adjusted, negligible improvement. The only thing left to replace is the car itself, as my other Toyotas have very firm pedals: 2000 Avalon XL (225K and beat to ---- by my sons on their journey to 21 and 19, respectively, but still a horse), and 2005 Sienna XLS AWD. Maybe could do some steel reinforced brake lines but the car stops well, and if my wife accepts it, we are done.
Typically a bad booster failure causes the brake pedal to become stiffer, as it is no longer being "boosted." Although I have heard in rare cases that the opposite occurs.
My sister has an '03 camry le v6(209000) and i feel that the brake are a little soft. The car stops fine but my cars brake are stiffer.
1989_Camry
Jul 21, 2017 01:22 PM
dividingbyzero
May 8, 2015 09:10 AM
stevehn
Apr 30, 2014 11:38 PM
d72polara
Aug 15, 2010 01:25 PM
d72polara
Aug 15, 2010 08:19 AM
