Old Aug 28, 2015, 04:52 PM
How-Tos on this Topic
Browse all: Steering & Suspension
Print Wikipost
vibrate when brake
Old Aug 3, 2006 | 01:23 AM
gungungungun's Avatar
Default vibrate when brake
I have a 2002 Camry w/ 50000 miles. Recently, when I drive like around 65-75 mph and hard brake, I felt vibration on my steering wheels and the front seats....can someone tell me what's going on and what should I do w/ my car??
Thank you!
Old Aug 3, 2006 | 12:21 PM
v6kamree's Avatar
Default RE: vibrate when brake
same thing happened to mine, got a wheel balance and alignment, all gone
Old Aug 3, 2006 | 02:53 PM
Thank you.
So you don't think is the problem w/ the rotor right??
How often do I need to do alignment???
-Gun
Old Aug 3, 2006 | 03:06 PM
trdcamrygracia's Avatar
it might be the rotor too...have u resurface or reture the rotor....u should get alignment check every 6000 miles or every 6 months
Old Aug 3, 2006 | 03:10 PM
Thank you!
How often do I need to chang the rotor anyway??
I dont' want to bring it to the shop cause I'm afraid they will say I need to change the rotor even when i don't need to....
-gun
Old Aug 3, 2006 | 09:02 PM
jasmtz531's Avatar
It is the front rotors, you can machine the surfaces, or replace them. You might as well replace them. Most shops now a days dont machine rotors they just replace. The shop where I work is the only shop around that I know machines rotors. There really isnt a set amount of miles you need to replace your rotors, just keep checking them. I usually tell people about every other oil change to check the pad and rotor thickness. The brake pads where faster then the rotors and I do NOT recommend replacing pads without machining or replacing rotors. Just take it to the shop and bite the bullet and get a brake job. Best advice I can give you.
-Jason
Old Aug 4, 2006 | 03:36 PM
lavalleemike's Avatar
just do the brake job your self its not all that hard.
Old Jan 31, 2007 | 04:08 PM
tim96460's Avatar
Front rotors warped, probably does it worse when hot right? Before having them turned make sure they are not warped. If you live by the ocean make sure that the inner vent area between the turned surfaces are not rusted/flaking, I have noted more tendency for warpage when that is noticed.
[align=left] [/align]
juarez1980
Nov 22, 2017 08:18 PM
CamryLastFoureverNever
Mar 16, 2015 07:57 PM
rapala13
Oct 3, 2013 04:49 PM
daileisu
May 31, 2006 08:10 PM
