Vibrations After Installing 20mm Wheel Spacers
Hey, guys! New member here and I used the search bar for this topic before posting this thread, but has anyone else experienced vibrations after installing wheel spacers? I have a 2021 Camry SE Hybrid and I just installed 20mm spacers about 2 weeks ago and I felt a little difference in the ride and didn’t really thought much about it and decided to do tire rebalancing and rotation during my 5k service. However, the vibrations are still here and it might be getting worse. Does anyone have any idea what’s going on and a solution for it or should I just go ahead and uninstall the wheel spacers? The wheel
spacers are KSP Hubcentric 20mm.
The Hub Centric system aligns the tire/rim to the axle via the hole in the rim and the flange on the axle. It doesn't use the wheel bolts to align the rim/tire.
Check for spacer fit up and excess play. Check for side movement of the spacer when installed on the car (no tire installed). And when the hub is inserted into the rim bore hole (spacer not on axle).
Are the mating surfaces of the spacer and car clean?
Are you tightening the bolts to the correct torque.
Would state call customer support but the company is in China.
