87 Toyota Camry 4 Cylinder manual Power steering pump ?
Old Jan 30, 2010 | 11:11 PM
hardyrxp's Avatar
Default 87 Toyota Camry 4 Cylinder manual Power steering pump ?
Hello Only when the car is cold and you turn the steering wheel you hear a loud squeaking noise. I checked the belt and it seems to be somewhat new and tight. I checked the power steering fluid level that is good. So my questions to you are..... Are the power steering pumps notorious for leaks or going bad in 87? What are the signs/symptoms of a power steering pump going bad? How can I find out if I can fix the noise or if I need to replace power steering pump? Have you heard of this problem or similar in a 87-91 Toyota Camry? Thanks for your help in these matters.
Dave
grocerygettercamry
Apr 26, 2012 09:53 PM
hardyrxp
Feb 3, 2010 02:43 PM
hardyrxp
Feb 1, 2010 10:16 AM
hardyrxp
Jan 30, 2010 11:11 PM
cbrc5eric
Jan 1, 2009 07:03 PM
