Camry LE 2005 Power Steering Fluid
Old Jun 4, 2012 | 07:00 PM
nowinnc's Avatar
Default Camry LE 2005 Power Steering Fluid
I am little down on power steering fluid in my Camry LE 2005. Toyota recommends to use ATF Dexron II or III. Can I use Valvoline Dex/Merc ATF.
Instruction on it says
MaxLife DEX/MERC ATF contains a blend of base oils and a unique additive package to help extend the life of transmissions with over 75,000 miles. It is formulated to maximize transmission performance, reduce transmission wear and improve and maintain smooth shifting longer than conventional fluids. MaxLife DEX/MERC ATF is compatible with new and rebuilt transmissions and will not void new car warranties. Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and LV, Allison TES 295 and 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
Will DEX/MERC work as a power steering fluid?
Old Jun 5, 2012 | 11:29 AM
Although not confident this product can replace the full list of fluids posted it can replace Dexron II or III.
Old Jun 19, 2012 | 12:08 AM
full house's Avatar
it work in few but not totally recommended, I don't know what they did to make it work.
gallootjs94
Aug 6, 2022 03:05 PM
nowinnc
Jun 3, 2012 11:31 AM
grocerygettercamry
Apr 26, 2012 09:53 PM
cbrc5eric
Jan 1, 2009 07:03 PM
melahi
Jun 20, 2008 09:49 AM
