power steering fluid leak
Old Sep 3, 2011 | 08:16 PM
gallootjs94's Avatar
Default power steering fluid leak
Hello,
I have a 2005 Camry that is leaking power steering fluid. A mechanic recently took a look at it and said the power steering hose needs to be replaced. Does anyone know where I can find detailed instructions on how to perform the repair (I saw a youtube video of the operation being performed on a different vehicle, but wanted a Camry specific instruction)? Also, what is a common approach to locate the leak? I want to make sure there isn't a simple solution to the problem.
Thanks in advance for any help!
-Johnny
Old Sep 4, 2011 | 08:59 PM
No help on the video. Might ask at the Toyotanation website.
Access to the pump is via the wheel well or under the car. If a PS hose, should be straight forward.
Old Sep 5, 2011 | 12:17 AM
full house's Avatar
you can try the vid and see if you can do some necessary changes to the procedure that might help and share it here.
Old Aug 6, 2022 | 03:05 PM
TerryS's Avatar
Default Power steering leak info
Originally Posted by gallootjs94
Hello,
-Johnny
Hi Johnny. I have a 2005 Camry and recently replaced a power steering hose and the resevoir. I watched several videos on the power steering leak issues, how to find and fix. I entered 2005 camry power steering leak in the youtube search bar. What line are you referring to? The high pressure, low pressure, mixed metal and hose, or just hose.
James3201
Jan 30, 2018 02:55 PM
elvis1977
Jan 22, 2013 08:44 PM
pagejesse86
Feb 12, 2012 10:04 PM
bassboobs
Jan 3, 2008 03:30 PM
Black95Cam
Sep 6, 2007 11:42 AM
