Just curious
Old Apr 7, 2010 | 12:16 PM
sebastian1023's Avatar
Default Just curious
I have a 1995 camry with just over 110k miles. I change the oil every 3k mikes with 10w-30. Would anyone recommend using the high mileage oil, or should I stick with regular oil. Is there really a difference. I do plan on having the vehicle for the long term. Also, I'm about to do a timing belt job on the car. Does anyone know where I can find a timing belt cover gasket? Thanks.
Old Apr 7, 2010 | 09:44 PM
Might try Rockauto on the gasket. It is a rubber seal that if not damaged can be reused.
Old Apr 22, 2010 | 08:54 AM
JayP71's Avatar
Rockauto is a good source if you don't mind waiting for shipping. Your local parts store will have something this basic as well. Personally I don't reuse gaskets that are that old. Also, you may as well replace your waterpump on the same job, as you'll be taking it off anyway.
Old Apr 24, 2010 | 03:09 PM
shooky100's Avatar
Don't recommend high mileage oil. If you live in a northern climate, you should consider 5w30 oil for colder months.....below 0 degrees F.
j05gtvert
Feb 7, 2006 07:23 PM
V6 5spdSTEF
Jan 21, 2006 03:17 PM
cam03TRD
Aug 19, 2005 02:36 PM
Lau77
Jun 27, 2005 05:18 PM
greylock
May 11, 2005 12:34 AM
