Rear Brakes
Old Mar 23, 2024 | 10:21 PM
Djski442's Avatar
Default Rear Brakes
Hello everyone. I'm having trouble replacing the rear brakes on a 2019 Camry LE hybrid with electronic E brake. I understand that you have to release the e brake in order for the pistons to release. I did the procedure and it worked. When to retract the pistons, they only retract about half way. Not enough to get the caliper back on with new brakes. Has any here experienced this before? Any help would be greatly appreciated.
Old Mar 24, 2024 | 04:37 PM
The videos below may help.
https://www.google.com/search?client...kPIPuLCP4Aw_34
The first video is the brute force method which does work..
Toyota has their own way which is the service method.
There are lots of videos on this.
Note the caliber motor can turn either direction by changing electrical polarity to move the pad in or out. Move it in not an out or it can pop out of the caliber.
Old Mar 25, 2024 | 10:23 AM
Djski442's Avatar
I did that, and it did release my parking brake. The problem was that the piston wouldn't retract far enough to get new pads on. I ended up removing the electric motor attached to the caliper. There's a torx screw behind the piston. I wound clockwise until it stopped. After that I pressed the piston back like normal. That worked.
joe6
Jul 25, 2022 06:57 PM
1989_Camry
Jul 21, 2017 01:22 PM
stevehn
Apr 30, 2014 11:38 PM
tbonejerry
Dec 13, 2010 09:53 PM
93camryxle
Sep 9, 2010 06:28 PM
