2010 Cigarette Lighter fuse out
Old 05-15-2013, 04:35 PM
SSGUNNER's Avatar
Question 2010 Cigarette Lighter fuse out
Hi everyone,
New guy here. My wifes 2010 camry LE lighter no longer works. Im assuming its the fuse since nothing that plugs in works. I think there are two lighters in the cabin and none work. Where is the fuse located? Never really touched her car before. Any info will be appreciated.
Old 05-16-2013, 11:23 AM
The may be a lighter fuse labeled CIG.
Location of fuse box may be behind the small coin box/ash tray/? on far left side of dash board below one of the climate system air outlets.
Remove the box lid and look behind.
Old 06-01-2013, 01:05 AM
BuddyLove2469's Avatar
I found the fuse on my 2010 Camry LE! It's down below, to the left under the steering wheel in a liitle pop-off fuse box. Just pull off the lid and look at the schematic. The fuse is on top, 4th from the right....
Old 06-20-2013, 03:25 PM
SSGUNNER's Avatar
Thanks guys. Havent checked this out. Will look at it soon and report back.
Old 07-22-2015, 04:40 PM
SSGUNNER's Avatar
Sup folks, so forgot to come back to this. I checked fuse and it was actually fine. I replaced it but still no dice. Can't think of any other thing that may be the issue. Both lighter locs do not work.
Old 07-22-2015, 10:37 PM
You sure these aren't the power outlets? If so, check the 20A PWR OUTLET fuse.
km670909
10-29-2021 08:02 AM
camryvasaq
07-10-2012 07:38 PM
Petes
09-02-2009 01:39 PM
pakixd
10-18-2008 10:55 AM
Collin16
07-26-2007 10:29 AM
Quick Reply: 2010 Cigarette Lighter fuse out
