2005 camry airbag frame rail sensor wires
Old 06-12-2020, 06:34 PM
gzcar's Avatar
Default 2005 camry airbag frame rail sensor wires
Hi Great forum my first post. Have a 2005 camry le 4 cyl my question is my friend installed a new front bumper cover for me and he pulled the two wires out of the drivers side frame rail sensor and i do not know where the wires should be installed i guess i have two choses since theres two wire ; does it matter which way there installed. Got a picture of the sensor in question from the web my wires are different colors than these.Any help would be great thanks GZ
Old 06-12-2020, 08:14 PM
What's the colors of the wires on the chassis?
For the sensor shown would assume the black/white wire is sensor negative. There is a sensor + and - connection at the airbag sensor assembly.
Old 06-13-2020, 06:04 AM
gzcar's Avatar
Hi my wires are one is green and the other white with a red stripe ;thanks for the reply gz
Old 06-14-2020, 08:26 AM
gzcar's Avatar
If anyone has a wiring diagram for this please let me know thks
Old 06-15-2020, 01:00 PM
The only colors found that were close are white/red and brown.
Brown is the negative connection.
For reference on plug pin location, for the part shown in your photo brown/white is negative and black/white is positive.
Old 06-15-2020, 06:30 PM
gzcar's Avatar
Thanks toyomoho i think iam on the right track with your help. I found this picture of my connector is the hole on the left which has b3 and 1 on it the number 1 side? Again thank you!!!
Old 06-16-2020, 12:13 PM
gzcar's Avatar
Update : someone sent me this picture of the wiring diagram looks like you we right colors show White -red stripe + , brown - side.
Also check out my picture of the sensor inside pin is marked with number 1 does this mean the brown - wire goes here thanks again
GZ
Old 06-16-2020, 09:47 PM
Great job!
Thanks for posting back with your findings.
bluedogz
04-02-2021 08:07 PM
Ewaddell82
03-11-2017 10:21 AM
ggino85
01-15-2017 04:26 PM
RtSE
01-20-2011 10:32 AM
DftMachine
06-26-2010 02:38 PM
Quick Reply: 2005 camry airbag frame rail sensor wires
