brake light issue
Old 09-20-2011, 12:51 PM
Hammerdown's Avatar
Default brake light issue
93 Camry. When I push brake pedal the bulb failure indicator on the dash comes on. In checking the bulbs all are ok. With headlights and running lights off if I step on the brake pedal the front side markers come on. Evidently a short but where would be the best place to start. Any help would be appreciated!
Old 09-20-2011, 04:41 PM
Hammerdown's Avatar
Let me clarify- the brake lights do work but the bulb sensor light indicates a bad bulb and with all running lights off when I step on the brake pedal the brakes lights do come on - but the front marker lights come on also.
Old 10-03-2011, 10:34 AM
Hammerdown's Avatar
Any ideas?
Old 10-03-2011, 07:39 PM
Run a test by removing all the brake light bulbs then setting up the situation you stated where the front running lights come on.
Check all dual filament bulbs to determine if one filament has broken off and falling on the other. The result may be power feed back into the wiring other the the brakes.
Check the wiring where it goes from the chassis to the trunk lid for damage.
Old 10-04-2011, 11:29 AM
Hammerdown's Avatar
I'll give that a try tonight and post results. Thanks for the response!
Old 10-05-2011, 07:57 AM
Hammerdown's Avatar
Removed tailight bulbs and same scenario. Opened trunk and marker lights did not come on. Closed trunk markers came on. Took covering and tape off chasis to lid harness and 4 wires broken. Case closed. Thank you for the assist!
Old 10-05-2011, 10:29 AM
Great!
Old 10-08-2011, 03:58 AM
453126437's Avatar
Good way,i guess wrong wiring connect
juarez1980
11-22-2017 08:18 PM
rlehr10
07-22-2013 09:30 AM
jessee
01-20-2011 11:55 AM
david.dickerson@solvay.com
06-18-2009 03:34 PM
Camrydriver
10-01-2008 08:47 PM
Quick Reply: brake light issue
