'01 Camry 2.2L 4 Cyl Timing Belt
Old 02-18-2013, 06:43 AM
ccrides's Avatar
rotating the crank two wimes to check the marks just makes sure you used tdc of the compression stroke. the first time around your marks wont line up the second time they should. crank at 0 and the hole in the cam gear spoke should have the uppermost notch on the cam gear housing centered in it.uppermost reffering to the mark that is at the highest point in the cams rotation,not 12 oclock.(since the motor sits on an angle not perpendicular to the ground.
Octapulse
12-07-2023 09:11 AM
d72polara
12-19-2012 11:58 PM
hawkaye
11-10-2012 04:53 AM
oldad
01-07-2012 07:28 PM
d72polara
10-27-2008 02:55 PM
Quick Reply: '01 Camry 2.2L 4 Cyl Timing Belt
