broken thermostat housing stud
Old 08-31-2016, 10:38 PM
millerboy's Avatar
Unhappy broken thermostat housing stud
I have a 2001 6 cyl Camry and I broke one of the three studs that hold the housing. How do you get it out?
Old 08-31-2016, 11:57 PM
dirty hands's Avatar
all three is bad luck
broken because of corrosion
if the engine block side of that housing for the thermostat cover
can not be removed or purchased
two options
if a bit of the stud is workable
heat up or weld a nut to what is viable
then undo
or loc-tight two nuts to remaining thread to undo carefully
if broken at the base of the stud
drill them out straight ... tap a new thread and helicoil kit
three new studs
dcmystery21
08-12-2008 06:30 PM
lancer409
01-06-2008 08:54 PM
fulcrumpointftt
08-21-2007 09:34 AM
02camSE
11-14-2006 12:53 AM
ecdhold
08-07-2006 08:48 PM
Quick Reply: broken thermostat housing stud
