2.2 engine swap 96 into 98 this possible?
Old 03-24-2009, 04:46 PM
kensand's Avatar
Exclamation 2.2 engine swap 96 into 98 this possible?
i have a 1996 camry that runs great ,but was in a bad accident . I am possibly looking to pull the engine and tranny as a unit and install in into a 1998 camry that has a bad engine. Is this possible ? will I have any problems doing this 2.2 auto tranny. 1998 is the same. thanks for any help.
Old 03-24-2009, 08:43 PM
The 1998 engine may have an improved ign system. Changes may include remote (not in distributor) cam and crank sensors or no distributor, separate ign coils, etc.
The computer on the 1998 will be designed for an engine with 1998 sensors, etc. You may have to swap a few parts between engines.
Suggest checking online websites such as Rockauto and comparing part numbers of the MAP, TPS, 02 sensors, etc then swap parts are required.
The trans should be OK.
Lemon07
06-23-2015 06:07 PM
Preditor631
11-07-2012 10:00 AM
carlos1787
05-23-2009 05:57 AM
Aaron
12-09-2008 05:09 PM
marv8
10-05-2007 09:02 AM
Quick Reply: 2.2 engine swap 96 into 98 this possible?
