Sponsored by:
Sponsored by:
Changing the Valve cover gasket 95 Camry
Old 12-16-2006, 02:34 PM
MauiGuy's Avatar
Default Changing the Valve cover gasket 95 Camry
Hi All,
I need to change it, but find it strange that the cover is bolted down with four bolts that go around the spark plugs. These bolts seem pretty large. I wonder what size wrench or socket would fit this? Or can I just use an adjustable cresent wrench? Any help or tips would be much appreciated.
Nelson
Old 12-16-2006, 09:28 PM
lavalleemike's Avatar
Default RE: Changing the Valve cover gasket 95 Camry
I usually use an adjustable you'll find the bolts are really short.
Old 12-26-2006, 10:32 PM
tim96460's Avatar
If you do this yourself only snug the nuts down, they break easly.
Old 12-28-2006, 01:01 AM
tim96460's Avatar
"what size wrench or socket "
Think it is a 32mm but a 36 will work
Old 01-12-2007, 05:01 AM
Joel_CA's Avatar
Its a 30mm. Don't over torque them or you may crack the cover. Just tighten them down in steps until snug.
J
Old 01-12-2007, 01:57 PM
geokor's Avatar
For specs on torque values and pdf downloadable camry factory service manual, goto:
www.turboninjas.com/camry/
Old 06-02-2008, 08:28 PM
JGRYoda's Avatar
New to the site so I apologize for digging up an old post! I just purchased my first Camry (96 4 cylinder). What supplier/vendor does anyone recommend to order the valve cover gasket kit and how much does it typically cost? Thanks everyone.
Old 06-03-2008, 05:54 AM
pedro's Avatar
It's not a kit, just a single rubber gasket. Buy from a dealer, I think about $20. Also use RTV sealant on sharp corners of gasket. Torque retaining nuts to 17 ft/lbs.
davj3368
05-16-2013 01:09 PM
CamRe
05-19-2011 08:05 PM
incubus
05-29-2010 09:46 AM
jones100001
12-08-2008 08:38 PM
trd_camry
04-11-2007 09:49 AM
Quick Reply: Changing the Valve cover gasket 95 Camry
