Sponsored by:
Sponsored by:
86 Camry-engine misses at 2000rpm
Old 10-30-2007, 09:59 PM
scn505's Avatar
Default 86 Camry-engine misses at 2000rpm
86 Camry LE HB with 5-spd manual.
Problem...at around 2000 rpm the engine misses and surges as if the ignition was cutting in and out. This only happens when driving under a light load and is worse when the engine is warming up, transitioning from cold start circuit to normal running. Not as bad when the engine is fully warmed up but still noticeable. Note that this problem instantly goes away when accelerating and the acceleration is quite good. It also doesn't happen when cruising on the highway at slightly over 2000 rpm, with or without cruise control engaged but you can still detect a slight irregular miss.
I've changed the plugs, plug and coil wires, distributor cap and checked the PCV valve. I used to have one of these cars 20 years ago and had the Haynes manual for it but seem to have lost it over time so I can't do a troubleshooting diagnosis. Anyone got any ideas?
Thanks.
Old 11-03-2007, 07:34 AM
pedro's Avatar
Default RE: 86 Camry-engine misses at 2000rpm
Have you checked for a vacuum leak?
kizersoze
01-22-2012 04:31 PM
tijuana_dude
01-06-2011 08:35 PM
chuck
03-24-2009 09:14 PM
farmallman
08-02-2006 03:20 PM
Quick Reply: 86 Camry-engine misses at 2000rpm
