96 camry DX 4cil, oil light on only until 2000rpm
Old Jan 5, 2011 | 11:35 PM
tijuana_dude's Avatar
Default 96 camry DX 4cil, oil light on only until 2000rpm
ok, so i changed the oil pump on it and it seems to work fine, only problem is that the oil light is on when started and will only go off if i go over 2000 rpm, any suggestions?
Old Jan 6, 2011 | 08:35 PM
Why did you change the pump?
Did you remove, install, change anything other then the pump, such as get into the area of the pressure regulator spring?
Did you install the gears on the new pump so the dot on each gear is facing the same direction?
Changing the pump should not cause a lose of pressure.
Does this engine have any sludge?
Suggest you don't start the engine until you install a test pressure gauge. It could be the oil pressure sender is bad, if not and now have really low or no pressure best stop running it until you solve the problem.
jellyculligan
May 25, 2011 09:37 PM
ziddey
Apr 27, 2010 10:12 PM
chuck
Mar 24, 2009 09:14 PM
mtnestr
Feb 21, 2008 02:32 PM
scn505
Nov 3, 2007 07:34 AM
