Sponsored by:
Sponsored by:
Security System
Old 03-18-2010, 02:42 PM
Kaddo's Avatar
Default Security System
Need help (desperately) to disable this annoying thing.
There is no hidden button or switch, as in most cases.
Is this an original, factory installed system?
Any suggestions and comments on how I should go about
disabling it will be greatly appreciated.
(Yes, I checked with the local Toyota dealer; didn't know).
Old 03-19-2010, 08:37 AM
If the alarm is factory or dealer installed it is most likely a VIP RS3000 system. This system can be programmed using the master ign key and going through a complicated procedure.
Suggest you do a Google search on RS3000 as the programming directions should be out there to download. This unit was very common in its time.
If the unit is a third party look for a switch of some kind under the dash. This would be a reset switch. Typically these units mount in part under the steering column covers. In the case of an after market unit it might be best just to remove it.
The Toyota units are very good thus suggest you find the info and disarm or reprogram it.
Old 03-19-2010, 09:54 AM
Kaddo's Avatar
Thank you, very useful info!
Yes, it seems to be a VIP RS300.
Unfortunately, the instructions refer to using the remote control, my car has none. If my car is not the remote kind, then how can I disable the alarm?
But if all cars were equipped with a remote, it's possible that mine got lost (not such rare thing to happen) by the previous owner. In that case, must be a way to program the unit manually, true?
Old 03-19-2010, 07:12 PM
There is a method of using the master ign key. Will determine if I can find.
Old 03-19-2010, 08:02 PM
Kaddo's Avatar
Thanks!
Old 03-21-2010, 09:46 PM
lin_2008's Avatar
Yellow stone diesel parts plant is one of the leading manufacturers
of engine parts, in particular diesel fuel injection system
accessories for replacement, such as Fuel injection Nozzle, Plunger and
Delivery valve, ETC In south of china .
for more detail please visit our website : www.yellowstonediesel.com
www.dieselinjection.cn
Yellow stone diesel parts plant was founded in 1997.Over the years,
Yellow stone has grown and gained a reputation for producing
high quality products and delivering them on time.
Old 04-09-2010, 05:39 PM
Kaddo's Avatar
Default Problem solved
I finally managed to disable my security system.
For those like me and who are still cursing, here is the procedure:
Step 1
Sit on the driver seat and leave the door open.
Within the next 10 seconds, insert the key in the ignition switch, turning it from LOCK to ON.
Repeat that 5 times and after the fifth, leave the key in ON position.
The horn will sound once and the red pilot light on dashboard will lit (solid).
Step 2
Within the next 30 seconds and still with the door open, turn the key back to LOCK position.
The horn will sound once. The light will blink rapidly a few times and then go off.
The system is now in Valet mode (disabled).
Important: The system will enable itself, if the car battery is disconnected.
Old 04-10-2010, 02:56 AM
lin_2008's Avatar
105015-5860
105015-5860
105015-5940
0 433 171 134
0 433 171 137
0 433 171 146
5611065 H60S30A538
5611650 BDL110S6133
5611735 BDL110S6267
6801082 6801082
6801087 6801087
6801088 6801088
DN10PDN130
DN0PDN121
HL176S27D525P2
2418455518 2455-518
2418455714 2455-714
9401087506 9087-506
134151-4120 P121
134151-4920 P129
134151-6420 P143
NOZZLE DENSO 093400-7690 DN10PDN129
NOZZLE DENSO 093400-7700 DN10PDN130
NOZZLE DENSO 093400-8220 DN0PDN121
131110-9320 131110-9420 131160-0320
lorenzo01
12-08-2007 08:36 PM
mrmatismysn
07-10-2007 04:29 PM
Jaxwild
06-09-2006 04:56 AM
ghosthorse
06-03-2006 08:46 PM
cam03TRD
04-12-2006 04:40 AM
Quick Reply: Security System
