Sponsored by:
Sponsored by:
Old 08-26-2015, 03:53 PM
How-Tos on this Topic
Browse all: Exterior
Print Wikipost
Squeaking steering column
Old 06-07-2006, 07:04 PM
Berryl's Avatar
Default Squeaking steering column
I have a 2002 Toyota Camry and the steering column squeaks during a turning when the weather gets warm. Has anyone had this experience?
Old 11-25-2006, 10:45 PM
toyotaadvisor's Avatar
Default RE: Squeaking steering column
you need to lube the boot on the firewall where the steering shaft goes through.
Old 05-07-2007, 11:00 AM
swataz's Avatar
Is theboot is located in the engine side of the firewall? And is this the same for a 2003 Camry?
Old 05-08-2007, 09:45 AM
kwtrading's Avatar
my 02 does this too so if it works that will be great. what do you lube it with? lithium grease?
Old 06-15-2007, 01:31 PM
yskarpe's Avatar
2003 toyota camry squeaking steering wheel...any solutions? How safe is it to continue driving in that state? It squeaks only when the wheel is rotated at static or near-static conditons...meaning, when reversing the car or moving out of parked spaces or steering at very slow speeds around sharp turns...please advise if it would be covered by toyota warranty?
thanks
Old 07-04-2007, 07:52 PM
pao648's Avatar
Parts of the steering linkage are loose and need to be tightened; your tires are hitting or rubbing against something; or you have worn suspension parts (ex: toyota suspension bushing). try to check it.. you could also ask the delear what might be the problem.. good luck
Old 07-08-2007, 08:01 PM
vivioman's Avatar
My steering had a squeak also that was mighty irritating...
The solution was to spray a bit of WD40 into the boot/rubber section where the steering column inside the car (near the pedals) that goes into the firewall section of the car.
paulm
07-17-2014 07:39 AM
Cristiano Vasquez Garcia
07-11-2014 10:58 PM
bas
11-08-2013 07:01 PM
plugeye
03-01-2013 06:35 AM
06CamChic
02-19-2010 09:55 AM
Quick Reply: Squeaking steering column
