Sponsored by:
Sponsored by:
Low, rough idle
Old 09-17-2008, 04:42 PM
mtgmike's Avatar
Default Low, rough idle
Car was exposed to high water with hurricane Ike. No codes are present, idle is low, 500 rpms, and rough with ac on, almost normal with ac off.
Old 09-18-2008, 05:30 AM
Default RE: Low, rough idle
What year and engine type.
What is the idle RPM when engine off.
How high the water get in the car.
How is the engine idle RPM when you shift from Park to Drive or Reverse, does it also drop (if auto trans).
Old 09-18-2008, 08:57 AM
mtgmike's Avatar
What year and engine type. 2005 Base model 4 cyl
What is the idle RPM when engine off. Im gonna go with 0 , Alex. 800 ac off/ 500 ac on.
How high the water get in the car. 4"
How is the engine idle RPM when you shift from Park to Drive or Reverse, does it also drop (if auto trans). Barely, not enough to worry about stalling.
Old 09-18-2008, 11:33 AM
jones100001's Avatar
my camry had starting/low idle problem only after a rainy day. I changed spark plugs and problem went away
Old 09-18-2008, 02:40 PM
700-800 RPM idle when engine warm and in gear is OK.
The ECU may not be getting a signal that the AC has been turned on. When the AC compressor turns on the ECU will adjust the idle up to compensate for the load. The throttle is controlled by the ECU via a stepper motor.
If the problem started with the the flood, perhaps some of the wiring connectors that were underwater are still wet. Flooding of wiring can cause all kinds of strange problems.
Old 04-06-2022, 04:05 PM
fixmytoyota's Avatar
Here is my video on:
How to Replace the Fuel Pump in a Camry
yxhjl
07-27-2015 09:35 AM
Zmacs
08-13-2012 07:01 PM
Longjohns
02-24-2012 09:19 PM
AvantA4
11-19-2006 05:00 AM
green97le
06-08-2006 12:32 AM
Quick Reply: Low, rough idle
