87 ignition coil check
Old May 5, 2007 | 05:44 PM
sb87cam's Avatar
Default 87 ignition coil check
What is the procedure for checking the ignition coil on a 1987 Camry 4 cyl. ?
Old May 5, 2007 | 06:59 PM
pedro's Avatar
Default RE: 87 ignition coil check
I'd first make sure there isvoltage from the wires. You can remove a spark plug andground it on the engine and see if you're getting a big blue spark. Make sure you disconnect the other plugs so it won't start on 3. I have a tester that tells me how many voltsare running through the wires and that will tell me what the output of the coil is. Of course you need to know the wires are OK first.If you're not getting a spark you need to make sure your primary on the coil is getting 12 volts.I've notlooked at one so I don't know where it would be as it's buried in the distributor.If primary voltage is there and no spark on output I'd say bad coil,bad, bad coil.
Old Apr 6, 2022 | 04:06 PM
fixmytoyota's Avatar
Here is my video on:
How to Test Toyota Camry Ignition Coil and Spark Plugs
mytecho
Jan 18, 2015 01:58 PM
KEVAUG
Jan 8, 2014 04:26 PM
johnradfx
May 27, 2010 08:29 AM
jwatson0823
May 30, 2008 11:27 PM
sb87cam
May 5, 2007 09:46 AM
