91 Camry won't start when hot
Old 08-30-2007, 01:06 PM
chopper75's Avatar
Default 91 Camry won't start when hot
Hi all, I'm new here. I have a 91 Camry and it won't start after I runningaircondition. It just click and click, and after approx. 10-15 trying then it starts. This is the 3rd starter I replaced, the last one I bough from the dealer. I 've never have any starting problem in the morning only when it's hot, after running the airconditionning then stop or after a couple stops on the hot day. Any idea or suggestion what may be wrong with the car? Thanks
Old 09-09-2007, 09:44 AM
cali714guy's Avatar
Default RE: 91 Camry won't start when hot
well maybe you should get a pressure check on your a/c system it can be tht you build up to much back pressure(a/c systems do build pressure)and after you stop the car the pressure stays there until 10-15 min until it releases and car starts.
Old 09-10-2007, 01:22 PM
chopper75's Avatar
Thanks for the reply.You mentioned thatthe AC built up pressure and I'm trying to thinkwhere the pressure will be? Would you mind to tell mewhere? Thanks
npn74
03-24-2020 02:38 PM
maxima8347
06-13-2010 11:13 AM
johnradfx
05-02-2010 04:53 PM
JDubya
08-18-2008 03:49 PM
Quick Reply: 91 Camry won't start when hot
