struts/shocks 2000 camry
RE: struts/shocks 2000 camry
in reality stock shocks are probably worn out by 75k miles , but its such a gradual reduction in performance that you really dont notice , until you put the new tokico,bilstein or kyb's in .
i think they are all about the same price . i just put on tokico's because they are slightly more forgiving on rough roads , but still have similar performance as the trd bilsteins that were on my 99 .
ORIGINAL: james007
How easy wwere they to replace?
the rear is a complete pita . you have to take every piece of trim out of the back to get to the upper mounting bolts . it took me longer removing the trim (breaking several little cheap clips in the process)
than the springs ., but all in all its pretty straight forward . pick up a haynes repair manual from an auto store it may come in handy .
i feel the car from the driver side low lettle abit from the passnger side from front
I have 2000 toyota camry 4 cyl
its 76,000 miles its excellant
conditions recently
i feel the driver side from the front wheel low rather than the passnger
i went to check it if it need alighiment but then result "alighmnet is complince with manufacturing company"excellent
is this from the shocks or springs??
conditions recently
