Flasher Relay
Old Feb 11, 2013 | 04:28 PM
20camry05's Avatar
Default Flasher Relay
Hey everybody,
I have a 2013 Camry SE V6 & I want to install switchback LED's. I wanted to know if anybody has replaced the flasher relay or knows where it is. I was told that you need to change the relay in order to make the switchback LED's work properly, I believe that is uses a CF18 flasher. Thanks in advanced.
Old Feb 17, 2013 | 11:29 PM
full house's Avatar
not yet did that, but from my friend's opinion your seem to be right you just need to change the relay.
Old Feb 18, 2013 | 11:18 AM
20camry05's Avatar
So, I went to a Toyota dealer to ask about the flasher relay. They looked up the wiring schematics for the flasher relay & it turns out that the flasher relay is built into the gauges for 2013. (I think it's b/c the 2013's have the 3 blink feature now) So, I guess that I can't install the flasher relays. I wanted to maybe find an LED that would keep the parking lights on but when it blinked, that bulb would completely turn off & on rather than just blink, I wonder if I could use a 7440 in there instead of a 7443 but I'm not sure if they would hyper flash even w/load resistors. I guess I still have more research to do...back to the drawing board.
Old Feb 19, 2013 | 08:53 AM
Are you sure the flasher is built into the dash gauges and not just installed into a plug in the gauge area?
See link below:
8-Pin 81980-50030 066500-4650 Electronic LED Flasher Assy Relay Fix For Lexus Scion or Toyota LED Turn Signal Light Bulbs : Amazon.com : Automotive
Old Feb 22, 2013 | 02:25 PM
20camry05's Avatar
See link below:
Well, that's what the dealer told me b/c I went there to see if they could tell me the location of the relay & they told me that it's now built into the gauges.
Old Feb 22, 2013 | 08:12 PM
Suggest trying the item in the previous post. It installs behinds the gauge area.
Old Feb 23, 2013 | 10:40 AM
20camry05's Avatar
Thanks everybody, I will try that. Does anyone live in the New Jersey area that can possibly give me a hand in tearing it apart to see?
Old Feb 23, 2013 | 01:40 PM
If need help post at the Toyotanation website, more members in more areas.
Rcs
Aug 18, 2015 08:04 AM
runner5113
Feb 10, 2011 10:43 PM
kmalley
Nov 7, 2007 11:08 AM
burnone
Apr 4, 2007 04:30 AM
neenie484
Mar 17, 2007 09:44 AM
