Browse all: Interior
- Toyota Camry 6th gen How to Install Aftermarket Stereo
Help: Replaced factory radio - 99 Camry
Replaced factory radio/cd player with Kenwood unit. Used adapter kit. Everything seemed to work perfect, and the new radio works. But now daytime running lights and dash (instrument) lights not work. Gotta be a wire not hooked up right, but which one? Any help much appreciated.
yes. Everything associated with the radio works. What doesn't work is (a) day time running lights, and (b) illumination for instrument panel (speed, tach, etc.) All wires are connected EXCEPT toyota's GREEN wire and WHITE-GREEN wire. These used to connect to toyota radio, but with new radio there is nothing (apparently) to connect these wires to.
No, but I really appreciate the response. I've downloaded wiring diagrams for the Gen 4 Camry and have studied them intently. I believe I have narrowed it down to either:
(a) the green to green-white wire connection shown on "ILLUMINATION" diagram, page 2, goes through the factory-installed radio and player to the light(s) of the radio so that the rheostat can dim (or brighten) all of the interior illumination lights. However, the green to green-white wires have no wires to connect to on the new, after-market radio I have installed. Thus, the rheostat will not dim the lights of the radio, nor does the rheostat dim ANY interior illumination light. Simply splicing the green and green-white wires does not work. (And, the daytime running lights do not work.)
or:
(b) splicing the green and green-white wires has caused a fuse to burn. Will check this next.
Bottom line is that Rheostat, illumination lights for instrument panel (speed, etc.), and daytime running lights all do not seem to work after removing factory radio and replacing it. FYI, I did purchase an adapter kit for installing the aftermarket radio, and all of the wires "lined up" perfectly. Only ones that didn't are the green and green-white wires mentioned above.
or:
Fixed it. It was a blown fuse (doh!), which I imagine was caused by splicing the green and green-white wires together. Unspliced wires; replaced fuse (7.5A), and dash illumination lights and daytime running lights resumed working.
Thank you for all the responses and assistance. I really appreciate it, and LOVE this forum.
highalti2d
06-20-2015 10:26 AM
tarasgrosh
10-28-2013 08:22 PM
lexingtondover
04-13-2011 02:02 AM
y2kwht150
07-26-2009 02:03 PM
yesnyes
04-19-2008 12:26 PM
