Need Help With Radio
Well i have a 92 camry and i have my stock radio in my car.. everything is plugged in and nothings out of the ordinary but now i have no power to it, my clock, and interior lights. if anyone can
....please tell me what i should do.
thank you
thank you
RE: Need Help With Radio
Sounds to me like a couple of blown fuses. I would start by looking there. If not i would take out the radio and test for power in the wireing harness. You should have a constant power yellow wire which should always maintain voltage and the a red wire that should have voltage with the key in the on position. If you have power at the harness check to see if you lights work with the radio out i've seen circuits in radios arc in a fashion that cause a short in the vehicle electrical system.
you need help man. think about an ipod integration kit. the one i have for my '99 Camry is a DICE kit. there the best that i've found out there. i doesn't lock out the ipod at all. i think they have new HD radio kits out now too,from '98-'07. check it out man.
i have a 2007 camry se with the jbl system and the built in bluetooth. I know that eclispe head unit works with the steering wheel controls for the audio, but i'm wondering if anyone knows if i can do anything to get the bluetooth controls to work with the head units?
rlmeredith
08-21-2012 07:33 AM
y2kwht150
07-26-2009 02:03 PM
