!!SOS!! BROKEN STEREO?!?! HELP!
Old Oct 23, 2007 | 06:52 PM
purtieswtpnay6's Avatar
Default !!SOS!! BROKEN STEREO?!?! HELP!
HELP A SISTA OUT!!!!!!!!
I recently obtained a 1992 Toyota Camry V6 LE. It's been under non-op for about 3 years. I purchased a new battery, new tires, new brakes, the works. After all the money spent, my stereo went out. The radio shows the station number when its on, the antenna goes up, I hear static but no music! I don't know if its a loose connection or I need a new stereo. What is a girl to do???
Old Oct 24, 2007 | 12:15 AM
boogz's Avatar
Default RE: !!SOS!! BROKEN STEREO?!?! HELP!
Well first check the back of the unit and see if there is in fact a loose connection. It should be a semi-thick black wire which runs from the antenna to the back of the unit. You never know, you might not need to spend any more money.
Old Oct 26, 2007 | 02:21 PM
Black95Cam's Avatar
sounds like it could be the speakers are blown or loose connections as you stated.
Old Dec 12, 2012 | 01:39 AM
Florentinote's Avatar
1BluSE
May 12, 2013 10:52 PM
oldad
Jan 7, 2012 07:28 PM
BugiSti
Oct 13, 2011 11:04 PM
rmknakal
Jun 30, 2009 09:47 AM
tomee
Jun 2, 2008 10:56 AM
