Subwoofer install questions.
Old Apr 29, 2023 | 11:25 PM
Kennythewelder's Avatar
Default Subwoofer install questions.
I just spent 12 hours trying to hook up a Sony explod 10, and a Sony explod 250 watt amp in my 2016 Camry SE XSP. I got a LOC and even bought a new Jenson 1200 watt amp, that was total junk. So, I switched to my old trusty 250 watt Sont explod amp, and that was w at least twice as loud as the 1200 watt Jenson. I got the only LOV Walmart had. It had a base adjustment ****. So after pulling all the new wires, I bought in the 1000 watt install kit, with a 6 ga power wire, I tried 2 different locations for the remote wife. 1st one was the charging fuse, then the W wiper fuse. Check to make sure that the power was going off with the key, but,,, the Jenson amp, would not go off. The Sony did go off, but after a few seconds, maybe a minute or so, the sub started buzzing. I am so frustrated. Help!!!!
Old Apr 30, 2023 | 01:10 AM
Did you hook up the amp input correctly to the stereo as either a line output converter or the low power output, as required?
Was the amp connected to the speakers at the correct impedance?
Did you install a capacitor into the power wire?
Assume the amplifiers lists a 12v power input amp rating. Make sure the 12v source can meet this. Might run a wire directly to the battery.
Cody Baker
Mar 29, 2019 05:37 AM
gooji18x
Dec 23, 2011 11:41 AM
brianjrealtor
May 1, 2010 08:06 AM
blackCam99
Jul 13, 2007 12:43 PM
nine five cam
Jul 13, 2007 10:42 AM
