Old Aug 25, 2015, 06:49 PM
How-Tos on this Topic
Browse all: Lighting Guides
Print Wikipost
'07 Camry LE DRL Module Install
Old Jan 11, 2013 | 01:39 AM
pimply1993's Avatar
Default '07 Camry LE DRL Module Install
Does anyone know how to enable the DRL on a 2007 Camry LE? I was informed that you need to purchase a module, and pay for an installation. Is it possible to install yourself?
Any information would be helpful!
Old Jan 11, 2013 | 07:42 PM
There is no DRL indication on the headlight switch?
Old Jul 31, 2013 | 12:29 AM
1296camry01's Avatar
It can be done, you'll need relays. Those are dimmed 50%, I believe. You should run a power switch for your dash. You can get a button that says drl on eBay for $23.00. I have an 01, I won't be dimming them so I will run a wire from the ignition switch to a fuse, then to the highbeam harness. I will install the drl button.2001s aren't dimmed much unlike 07s. But in bright daylight, you can't even tell really.
sonamu
Nov 30, 2011 09:19 AM
CaptainJEH
Sep 17, 2007 05:50 PM
jcaron
Aug 20, 2007 03:25 PM
vanagonrabbit
Jan 24, 2007 07:07 PM
99camry
Jan 2, 2007 08:50 PM
