Browse all: Lighting
- Toyota Camry 4th, 5th, and 6th gen Why Are Headlights Dim
Guide to diagnose trouble and recommended solutions.
Headlights always in DRL mode
Hi everyone!
I have a problem with the headlights on my '99 Camry. It has DRL and auto lights so it used to work like this, depending on the light switch on the steering wheel:
- OFF: all lights are off, headlights and dashboard
- Auto/DRL: dim headlights during the day, full lights at night, dashboard is lit. I have been using this setting for 7 years without touching anything
- ON: full headlights, dashboard is lit.
Here is what it is today, regardless of the ON/DRL/OFF switch position:
dim headlights as if in DRL mode always (day or night), dashboard is lit.
Basically, at night I don't have enough light (and for some reason I cannot turn it off).
Does anyone have an idea about what it might be?
Not so long ago I had replaced the brake light in the middle, not sure if this has something to do with such behavior...
Another interesting fact is that when I just turn the car on everything works normally. But about when I start driving it goes into "DRL mode", i.e. lights either turn on (if switch was in the OFF position) or lights dim (if it was in ON). I could not figure out the precise sequence of events like brake pedal or gear switch, but itlooks like itmay besomething related.
Thanks in advance!
- C
Thanks in advance!
- C
lil heezy
Oct 30, 2011 07:08 PM
