07 Camry Radio question
I just purchased an 07 Camry LE. The dealer was sloppy in detailing it, and while spraying the dash, got fluid behind the radio lens, which now has run marks on the back. I need to remove the radio lens safely, I hope. Can anyone tell the best way to proceed, and any pictures on how to remove the moldings around the radio that I think will be necessary to do this? The lens moves around a bit, so I think it should be able to be removed. Thanks
Some times you can go to "You Tube" and put in that question. I know I now know how to remove the headlight by doing this. The radio might span a few year so maybe a 2006 0r 08 would be the same. A stereo installation store could probably help you out as well. Most of the interior parts snap out with light prying. Good luck.
pixshooter
Sep 30, 2009 12:25 AM
