1995 Camry Fender Replacement
Old Dec 26, 2019 | 12:19 PM
wdc123's Avatar
Default 1995 Camry Fender Replacement
I can find fenders but being in he Midwest they typically have rust on the bottoms however there are new ones non oem but don't know what to buy.
Here is Rock Auto - What manufacturers are good and what certifications are applicable so I have the nearest match to OEM,
35 bucks seems cheap.
Various Manufacturer product is sourced from manufacturers such as TYC Genera, TYG, DEPO (MaxZone), Kool-Vue, and Eagle Eyes. Sometimes our warehouse's inventory may have the same part from two or more manufacturers, which is why we cannot guarantee which brand you'll receive. Regardless of the manufacturer, these parts are designed to fit and function as the original equipment did. Body parts come in different quality levels (not all of which are available for every application):
  • OE NEW parts are supplied directly by the Original Equipment Manufacturer. These parts are the same as what the vehicle manufacturer installed on the assembly line.
  • CAPA CERTIFIED or NSF CERTIFIED parts bear the seal of independent, third party organizations guaranteeing fitment and quality equal to original equipment. These parts may be required if your insurance company is paying for the repair.
  • PREMIUM LINE parts are made of a higher quality material than regular inventory or economy parts
  • REGULAR INVENTORY parts are designed to be equal to the original equipment in fit, function, and quality.
  • ECONOMY are less expensive and may be less durable and/or a less-exact match for original equipment than other lines. Processes used to produce Economy Line parts may result in striations/markings, uneven edges, etc. This is normal and is not indicative of a defect. When replacing symmetrical parts (like taillights or mirrors), we recommend replacing both sides to ensure they match (small differences in gloss or color compared to original may be noticeable if you replace only one side).
  • RECONDITIONED parts are OE quality, have been reconditioned and are ready for preparation and paint. Primer color of parts may vary.
  • OE TAKE-OFF parts are supplied by dealerships. The parts have been removed from new vehicles, usually because a customer chose to customize the vehicle they were purchasing. The parts may be painted or come with additional parts such as sensors or brackets.
Note: Clips and retaining components are not included with body parts.
Sheet Metal Location Guide For Cars And Trucks
Old Dec 26, 2019 | 03:22 PM
If available,a Toyota fender would be the best but most expensive.
Next would be a used Toyota fender off a junker or parts car.
CAPA parts are supposed to actually fit up and are tested for corrosion resistance etc.
Don't know about the rest but they can be hit or miss.
Find the OEM part number and do a internet search on it and the word "CAPA."
Once a fender maker gets a stamping die made and set up, the actual cost to make the part is cheap. The cost of sheet steel and labor.
Check out the link below. Have no knowledge of this maker but they do offer painting.
https://www.chicagoautobodyparts.com...=camry+fender+
Old Dec 27, 2019 | 10:12 AM
wdc123's Avatar
Thank You.
RCS1300
Oct 13, 2015 01:39 PM
carid
Oct 16, 2014 03:57 AM
iconman
Jun 4, 2014 11:00 PM
camrygarage87
Jul 17, 2013 05:22 AM
RockAuto
Jun 15, 2012 12:53 AM
