Is there a trick to removing the 1999 Toyota Camry Starter Relay? Even with using this Lisle 46950 Relay Puller Pliers and pushing apart the tab, I am unable to pull the Relay out. Do I have to grab the bottom white part or rock it from a different direction or something? Must be something easy but I don't want to damage anything accidentally so wanted to post here first. Thanks for any tips. Jimmy.
Search the internet for complete photos of the specific relay part number. The photos show a tang extending inward from the white body section. This tang could be preventing the relay body from being pulled out.
One can also try Toyotanation.com and do a general search. Assume this relay is used in lots of Toyota models and someone has had the same issue.
