2010 Camry 2.5 liter le belts replacement questions
Old Aug 27, 2018 | 05:03 PM
Dubi2017's Avatar
Default 2010 Camry 2.5 liter le belts replacement questions
Hello. I have gone through the video guides for changing the serpentine belt on 2007-2011 Camry's. However, none of them have 2 belts like my gfs car. Seems like it has a serpentine belt for the water pump, alternator, and air conditioning and a multi v belt for the main drive belt.
The accessory belt broke during driving and I have to remove the drive belt to replace it so I am trying to replace both belts. My tensioner has a 14 mm for the accessory belt and a 14 mm for the idler pulley on the main drive.
Any help would be greatly appreciated. I am at a loss here.
Thanks.
Old Aug 27, 2018 | 06:32 PM
twogigahz's Avatar
SLOWLY turn the REAR tensioner. It's hydraulic, and if you horse on it too hard too fast, you will bust that adjustment nut right off of it as it's only aluminum and then you are in for a whole lot of work.. Go buy a serpentine belt tool, too, just for leverage. Slowly pull the tensioner so you can slip the accessory belt on. Doesn't look like on mine that you need to mess with the main belt at all, it has its own tensioner.
Old Aug 28, 2018 | 08:30 AM
Dubi2017's Avatar
Thanks. I figured it out. Had to remove the PS belt to install the serpentine belt. Have to exchange the PS belt as I don't have the correct one.
Denniss
Aug 28, 2017 10:19 AM
technut
Dec 29, 2016 10:25 PM
usnavyvetmissouri
Mar 23, 2008 02:55 PM
berries674
Mar 23, 2008 01:45 PM
CKSAMartin
May 22, 2006 04:33 PM
