2011 Camry A.C. issue
Old Jun 21, 2018 | 07:21 AM
NYGMEN's Avatar
Default 2011 Camry A.C. issue
Sometimes when I turn on the A.C. it will blown out hot air for a while. After about 5 minutes or so it will finally blow cold air. Feels like a flap is stuck. I've tried turning the **** from cold to hot and back, changing the direction of air flow but it does not affect it. Please help.
Old Jun 21, 2018 | 11:33 AM
Is the AC turning on and working correctly?
Auto or manual controls?
The climate control system uses a "blend" door to mix hot and cold air. The actuator is on the passengers side of the under the dash HVAC console. Determine if you can see the actuator arm move when you adjust temperature.
Old Jun 21, 2018 | 03:13 PM
NYGMEN's Avatar
yes the AC is on and blows cold air once it operates. It is manual control.
Old Jun 21, 2018 | 03:51 PM
The blend door inside the climate control air ducting my be sticking. This door blends hot and cold air to the requested temp. If the door is stuck in the hot position, the outlets will have hot air.
The AC system may be low on Freon. The low Freon resulting in a lag in creating cold air. The pressure can be easily checked with the proper AC gauge set.
Chao.0724
Jan 7, 2023 04:17 PM
Rouds39
Apr 20, 2019 04:39 PM
shakebaker
Aug 8, 2012 08:43 PM
Duke
Aug 29, 2011 03:52 PM
richpngu
Jun 1, 2010 07:11 PM
