2014 (7th Gen) Camry Motor Mount Torque
I need to get the torque specs for the front and left lower motor/transaxial mounts. The front mount has a 17mm bolt at the top and three 14mm nuts at the bottom. The left mount has a 19mm nut at the top and three 17mm nuts at the bottom. Can anyone help with this?
Best I could find online:
Hope it helps, I accidentally pulled the stud on my new transmission motor mount torquing the stud bolt to frame 100 ft/lbs with a torque wrench, granted it was a non-oem part from Anchor made in Thailand, smaller studs than OEM and held in with a small spot weld.
zcpro
May 26, 2009 12:10 PM
