motor mounts ?
Old Aug 8, 2007 | 10:34 AM
trd_camry's Avatar
Default motor mounts ?
Anybody here attempt to do motor mounts on a 97-2001 v6 ? I'm getting a humming and vibrations from the engine and with 120k miles on her , I'm sure the motor mounts are the culprit . Any tips on doing this ?
Old Aug 14, 2007 | 11:50 PM
toyoboy's Avatar
Default RE: motor mounts ?
usually if the motor mount it loose the mount on top of the timing belt will have a torn bushing...but to replaced the front and rear mount you will just need to remove the mount on top of the timing belt and jack the motor with a floor jack as high as you can go, with the front and rear mounting fastern remove of course...the front comes out pretty easy the back is a little tight..
Old Aug 15, 2007 | 11:40 PM
vin888's Avatar
if you tighten the nut in the middle of the strut mount. does the strut suppose to move?
Old Aug 18, 2007 | 01:46 AM
vin888's Avatar
how do you check if the front and bacck motor mounts are bad already?
they are oil filled right? (hydraulic) for the gen 4 camrys
Mark DiSilvestro
Nov 5, 2013 09:12 PM
elvis1977
Feb 11, 2013 07:31 PM
ldballoon4
Jul 12, 2011 09:55 AM
brianjrealtor
Jun 25, 2010 09:24 PM
4x4man
Jan 1, 2007 06:05 PM
